Remove google search from browser
  • 5 replies
  • 2 have this problem
  • 6 views
  • Last reply by RageE1der
Are use DuckDuckGo not Google. I can't seem to remove Google search from fire fox for iOS. Help. Thanks.
All Replies (5)
Hello,
If you prefer using DuckDuckGo, please go to Settings -> General: Search
Set DuckDuckGo as your default search engine. You can also turn off Google from the Quick-Search Engines section.
Hope that will work!
I did both. When i search for something it still comes up in google. I dont have this problem with firefox on pc. Thanks
Aha i just figured out how. I changed my default search engine to duck duck go and turned off google.
Goggle has returned. After selecting duckduckgo as search engine and turning off google one day later google is back when i attempt a search from the URL bar
Hi rlbridge
Take a look at this article that can help you enable or disable search engines. https://support.mozilla.org/en-US/kb/enable-or-disable-search-engines-firefox-ios
His article can help you to change your search engine on ios https://support.mozilla.org/en-US/kb/change-default-search-firefox-focus-ios
Modified by RageE1der
